Motor Mercury 125 1997/98
Tach Mercury
Question 1: How can one test the tach output (gray wire) of my regulator to make sure that it is working?
Question 2: Some one told me to splice into one of the yellow wires coming off my stator and it will give me the same readings that the gray wire would on the regulator? Any one have any experience with that?
Question 3: What settings should I put the tach on? 5P? This is what the original one was set to.
Background: I have 2 tach's and I can not get either one to work. I even bypassed all the wiring in the boat and connected directly to the Regulator to bypass any onboard issues, including ground and power wires.
I can not find any documentation on how to install an tach in a boat and certainly can not find anything on a Mercury tach.
Thank you all for your support.
Tach Mercury
