Hullo ( <br /><br />My gears make a grinding noise when I put the motor in REVERSE and not when in FORWARD. The gear cables are not slipping and all screws have been tightened.<br /><br />Can someone with a EXPERTISE in this motor please reply as to what miht be going on inside the motor. There is no clutch just two mating cogs so whats the problem?.<br /><br />Also water comes out midsection of motor when muffs are feeding bottom inlet vent with water. This is when motor not running. When motor running water does not run out mid section but through normal outlet. Is it possible that there is a brak in the hose or something like this?. But the pressure out of the outlet is not strong but reasonable. Again an EXPERTS comments please.
