Re: Mercury tilt stop switch
The mercury switch will not allow your Motor to attempt to start(Starter will not even turn) if it is defective. But,I assume that you can turn it over to check for spark, as you say you have none. So, I don't think that is your problem. I am not real familiar with Mercs, although I did have a 67' 65 HP many years ago and I remember the mercury switch was a safety to protect your motor from turning over and starting if the motor was tilted in the "Up" position(Out of the Water). You may be able to get more help from others as to what the real problem is. Good Luck,
