Mercury trim problem
shkntstrd
I have a 2001 24' Bayliner Trophy with a 150 Saltwater mercury outboard. Up to now my power trim has worked without any problems. But tonight a tried to raise it (it is full down right now) and I can't get it to move with either the throttle switch or the switch on the motor. Both batteries are fully charged and I can hear some kind of soft clicking noise when I push on the trim switches. The relays appear to be working I get good volts on the wires down line of them. Is there some kind of circit breaker somewhere in the trim system? Just trying to save the fishing trip tomorrow!!!
naiscoot
Re: Mercury trim problem
I have the same motor with the same problem. Have you tried cleaning the tilt and tirm toggle switch?
naiscoot
Also where is your switch on your motor? My mechanic said 8 of 10 it is the actual toggle mechanism.
shkntstrd
I think I have it troubleshot down to the trim motor, I pulled it off and it will barely turn when you push the trim switch. I'm going to pull it apart and clean the brushes and give it a try. Thanks
