Hi all, I have two problems that I am sure someone will know the answer to point me in the right direction. Mercury V6 175hp 1979 Blueband. The general problem is starting, if the carbs are stripped down cleaned and reassembled then she will start and run for about 3 to 5 minutes before stopping then will not restart. There is plenty of clean fuel in the line and all carb bowls are full. Problem one: the carbs are WH7 1A , WH7 2A and WH7 3A. According to the standard jet table the vent jets in cylinders 3,5 and 6 are ?none? now does this mean that there should be a blank jet or no jet at all? Currently there is 80,80 and 90 respectively. Could this be a problem? Unfortunately I have no history on this engine. All the main jets and idle jets are to the standard jet table.
Problem two is synchronising the engine if I set up No 1 at tdc and bring it back to 0.462in the 0.462 mark on the flywheel is not even in the timing window let alone near the pointer so as you can see I have a problem in trying to synchronise the carbs and timing. Could this be the wrong flywheel cowl? Or is there another way to synchronise the engine?
Any help in this would be greatly appreciated
Thank you
Graeme
Thank you
Graeme
