Mercury v6 lower unit
Karl_Childers
I have a 1988 200hp black max with a bad L/U. I have shimmed gearcases in school (MMI) but that was 2 years ago. I haven't managed to get it apart yet, and am considering cutting the bearing carrier out. Do you have to pull the shift shaft to get the bearing carrier out?
Thanks!!
Rob
Faztbullet
Re: Mercury v6 lower unit
You are opening a can of worms on this unit. First mercury didnt use a preloaded driveshaft in 1988, 1985 was last year when they went to upside down bearing. If you damage housing, you can only use a pre 1985 as the driveshaft housing area are different milled, thus you cannot take a newer style shaft & bearing and convert it. You cannot use the gears in a newer housing as they are cut different thus the preload shaft. The shift shaft only needs removed to remove prop shaft.
Karl_Childers
So i could use a large gear puller to get the carrier out using the propshaft as a pressing point?
Faztbullet
Kind of as long as the puller jaws do not dig into sides of gearcase. I would soak it in a good penetrating fuild(not WD40) and use heat as salt water makes em grow together.
