I have a 2011 Mercury Outboard 60 hp 4 stroke engine. I was running it on the water going about 25 mph when everything shut down leaving me stranded in the middle of the lake. I had no power to the ignition, live wells, or anything. I carefully removed the cowling and checked the main fuses to the motor. The 15 amp fuse was blown. I replaced it, and then started the motor back up. I then ran idle speed back to the boat ramp. Four years ago, I had the same thing happened. I took it to the Tracker dealership for repair while it was still under warranty. They said the voltage regulator was bad, and they replaced it. If this is happening again, I wonder why they go bad. I have a 2 year old starting battery that I keep fully charged when not in use with a Minn Kota onboard charger. Any advice is greatly appreciated.
