the question i have is there supose to be a seal between the plastic tube out from the water pump to the copper tubing coming from the engine? If so is it an o ring just slide it on the copper tubbing and install the whole lower unit? 1973 Mercury 150 tower of power--the reason i'm asking is i'm only getting about 10 pounds of pressure at 4500 rpm's i do have the tell tale stream of water out the enging but it is not very "strong" also what is a poppet valve for the water pump- i really don't think my motor has one but if it does were is it located?
