Mercury wiring CAN work just fine, but there are some differences.
I have a 95 Force 90 hp Sport jet with Mercury ignition wiring and the #1 and #3 cylinder colors are swapped and the timing bias circuits are different.
I used Mercury CDM modules with the old style trigger coils and flywheel.
In the CDM system the bias circuit is built in the trigger coils and the magnetic circuits are not compatible with the older flywheel.
I am working on verifying the bias circuit this fall, but traveling currently and it has been too hot in Navarre for this old man to work on it much...
When I have had a chance to completely test it out I will post the schematic i used which is basically three diodes and a resistor to offset the increased voltage from the trigger coils as the rpm increases to track the advance curve properly.
The idea is that the trigger for the CDM is about .6 volts and the increasing voltage from the trigger as the speed increases moves the firing point on the voltage ramp advancing the timing in addition to the cam on the throttle.
If anyone has a timing curve for the Force I would appreciate having a copy
