Mercury XR6 Problem/Solution??
ifishhard
I have a 2003 Mercury XR6 150. yesterday I took this boat out for the first time. It cranked up fine, idled fine, even hit WOT/Holeshot fine. Well about the 6 session or so of starting it, It turned over for like 3 sec. then died. Then it wouldnt crank (fire up) it wouldnt even turn over, just starter spinning, but no fire, had plenty of battery juice......So I decided to let it sit for about 15 minutes in fustration. Tried to start it agian and BAM it turned over, BUT When it turned over I had to give it gas to get it to run. SO I continued on with my day and it cranked up fine for pretty much the whole rest of the day, then AGIAN later that day it did the same thing. So when I got home I took my fuel pump apart and noticed some trash in it. Wasnt alot, mabey around 5 or so flakes in it....Almost looked like brown flaky stuff. I rebuilt my fuel pump and replaced my bulb. Could this little bit of trash cause this issue????? If not, what should I check?? Thanks!:confused: FYI, I also noticed my bulb wasnt hard when it wouldnt start, that is what was making me think, Fuel pump........
CharlieB
Re: Mercury XR6 Problem/Solution??
"wouldnt crank it wouldnt even turn over, just starter spinning"
Perfect example of a low battery or poor connections.
Clean ALL connections on battery cables, BOTH ends.
Check battery voltage, then aagain again while running to see if the charging system is working.
ifishhard
Sorry, when I said it wouldnt crank I meant Fire up, I think It may have been flooded?. It had PLENTY of juice in the battery! I just bought it! That is why I am leaning to the amber colored plastic sediments in the fuel pump....
Faztbullet
Since you said you just purchased ,I am guessing the boat set with old fuel in it? Did you add fresh fuel?
ifishhard
YEs....The guy I bought it from did run the boat and crank it. Never let it sit up. He also had mercurys fuel stabilizer in the gas.....
