Mericruise exhaust manifold crack
JoeFo86
Hi I have a mericruise alpha one 305 gm engine and it has a cracked exhaust manifold guy I got it from said he didn't winterize so that's why it crack. Soooo my question is do I need to replace both manifolds or can I just do the one and call it a day?
Bt Doctur
Well, its your motor but I would do the pair but before I spend money I would make sure the motor is still good
Ayuh,..... Welcome Aboard,..... If that's the case, I'd suspect you also have a cracked block too,.......
