MFG Westfield YEAR???
cor1580
I was just given a MFG Westfield 9012 (only numbers on hull tag) but every pic i see in the reference pics shows only outboards..... This boat has a Renault- Mercruiser I/O combo from 1968 .... Boat is pretty descent shape considering the age... I am hunting two carbs however or parts to them. Can anyone help with the year and or parts locations? Thank you very much!
mr 88
Re: MFG Westfield YEAR???
Just looked on fiberglassics mfg info in there library,1964 shows a Westfield I/O under the spec sheets. I will let you search the literature and see when they stopped with the I/O on the Westfield.Now this boat may have sat on a dealers floor for a few years before being sold and when it was they may have registered it as a 1968. Or someone along the line may have misread the year and it is now a 1968.My Power Cat is registered as a 1967 but the hull ID plate shows it was made in 1966.It was easier back then to get things mixed up with no big repercussions.
As far as your carb questions and parts I would post in the misc motor/outdrive section if there is not a specific Renault listing.Someone made the carbs for Renault,maybe check a NAPA type store,,good luck!!
cor1580
The serial numbers from the motor shows its a 1968.... but yet the boat doesnt match anything 68 or newer. Going to try Napa. Let you know how that works out!
