Michigan Prop number - Can't find ID?? SMC 318
Chinewalker
I picked up a few props last weekend and need to ID one of them. It looks to be a MerCruiser style prop, about 15-inches in diameter, aluminum 3-blade. It's a Michigan wheel, and the number on the hub appears to be SMC 318 (possibly 316). Also has a second number stamped in the hub - A10648. 15-spline bore. I've had good luck IDing props through either the Michigan Wheel site or the database at the AOMCI site, but this one comes up empty. Anyone have a clue? Thanks!
- Scott
Re: Michigan Prop number - Can't find ID?? SMC 318
Ayuh,...
I can't help, but I bet Debbie over at Don's Prop Shop could give you an answer.....
