I have a 1999 lowe 179 scx with a 1999 evinrude 90 hp fichtBoat. was bought used and had a michigan prop model 011024 14dia'' x17pitch'' 3 blade. while on vacation bought a new evinrude prop model 177131 14'' x 17'' as per dealer req. both props will run out good at about 5500 rpm but the new prop will not take sharp turns at all. Engine over revs and will not bite. Pull back on throttle and hit it again and will take right off. I have tried trimming out at all different rates and only if i hold motor down all the way will it try to work.
