Microsoft PowerToys for Windows XP
Ralph 123
http://www.microsoft.com/windowsxp/pro/downloads/powertoys.asp <br /><br />They're back! PowerToys are additional programs that developers work on after a product has been released to manufacturing. They add fun and functionality to the Windows experience.<br /><br />Note We've taken great care to ensure that PowerToys operate as they should, but they are not part of Windows and are not supported by Microsoft. For this reason, Microsoft Technical Support is unable to answer questions about PowerToys. PowerToys are for Windows XP only.<br /><br />Important Notes<br />You must uninstall your old PowerToys before installing the new ones. <br />PowerToys will only work with US-English regional settings. <br />Just look at your PowerToy choices:<br /><br />Open Command Window Here<br />This PowerToy adds an "Open Command Window Here" context menu option on file system folders, giving you a quick way to open a command window (cmd.exe) pointing at the selected folder.<br /><br />Alt-Tab Replacement<br />With this PowerToy, in addition to seeing the icon of the application window you are switching to, you will also see a preview of the page. This helps particularly when multiple sessions of an application are open.<br /><br />Tweak UI<br />This PowerToy gives you access to system settings that are not exposed in the Windows XP default user interface, including mouse settings, Explorer settings, taskbar settings, and more.<br /><br />Version 2.10 requires Windows XP Service Pack 1 or Windows Server 2003.<br /><br />Power Calculator<br />With this PowerToy you can graph and evaluate functions as well as perform many different types of conversions.<br /><br />Image Resizer<br />This PowerToy enables you to resize one or many image files with a right-click.<br /><br />CD Slide Show Generator<br />With this PowerToy you can view images burned to a CD as a slide show. The Generator works downlevel on Windows 9x machines as well.<br /><br />Virtual Desktop Manager<br />Manage up to four desktops from the Windows taskbar with this PowerToy.<br /><br />Taskbar Magnifier<br />Use this PowerToy to magnify part of the screen from the taskbar.<br /><br />HTML Slide Show Wizard<br />This wizard helps you create an HTML slide show of your digital pictures, ready to place on your Web site.<br /><br />Webcam Timershot<br />This PowerToy lets you take pictures at specified time intervals from a Webcam connected to your computer and save them to a location that you designate
