Hi, I am starting to work on a 1965 Sears fiberglass boat with Elgin (McCulloch) 45 HP motor. The motor appears to be in good condition, knock on transom wood, and with the cover off the only apparent work I can see was on the fuel pump (slightly mangled bolt heads).
Four years ago I see the last owner of this boat asked a question on this forum about procuring a throttle cable and to judge by the current status, he did find it!
After spending a week stripping and repainting the trailer I am finally starting work on the boat. Have already installed the Pretech rotary steering upgrade purchased here on iboats. Slick.
The ignition switch was obviously sticky and dirty inside so I replaced it before proceeding. Now I can turn the key to crank for a moment, and yes, I do get a brief crank before letting off. The "choke" button is separate and I hear what sounds like the fuel pump when pressing the button (seems normal to me).
Now to my question: On putting the key back to "on" (motor isn't running -- I just wanted to test if the starter activation would work), I smelled a hot or burning smell. It was obviously coming from the vicinity of the ignition switch and seems to be from a large ceramic component adjacent to the switch. I measured the current and it is almost 7 amps. This is with no lights or anything on. Man, that would run the battery down quickly if you left the key in the on position, not to mention catch the boat on fire possibly! Obviously the big ceramic component is there for a reason. I guess it is a resistor and certainly does dissipate the heat.
Is this normal? What happens then when the motor is running?
Also, assuming all the above is OK, what is the proper way to use the "choke" button? Just a brief "buzz" before cranking the motor? And a couple primer bulb pumps before that?
THANKS
THANKS
