Mid 80's 60 hp Water Pump Impeller Key???
jimi
I have a mid 80's Evinrude that had a water pump failure. When I went ti remove the Impeller from the I had a heck o f a time due to some corrosion on the Drive Shaft. Once i managed to slid it up (after cutting of the rubber) by prying in up the Drive Shaft a sliver of white plastic (lying in front of the shaft in the picture) fell off of the flat on the Drive Shaft (a bit hard to see but just visible in the photo).
I was expecting a key similar to the parts list I'm holding in the photo background.
Has anyone seen this before? What is the fix?
Thx
There may be no need to " fix " anything.-------Later motors used a plastic key like you have.----The picture shows a woodruff key used on an old V-4 motor.----Just order a new impeller for say an 88 model and it will come with a set of plastic keys .---Use the white one !
