When you pressure test the drive, you aren't testing the bellows.How did the milky oil get in the bellow if it holds pressure?
Merry Christmas Guys!
I'm having a similar issue, so I'm going to jump in.
VP280 drive. I drained the outdrive yesterday and the oil was milky. I then loosened the drive bellow and milky fluid came out of it also. I put pressure on the drive without fluid and it holds 15psi. I filled the outdrive with oil and put 20psi on it again, still 20psi an hour later and no leaks of oil.
The drive bellow looked in good shape and is about 2 years old. I ordered a new one and will replace next week.
My only guess is the drain plug was the issue, it had a split in the oring, but I never noticed any leaks.
