Milky oil in lower unit
vdimenna
I have 1996 Ocean Pro. Drained the gearcase at the end of the season to find milky oil. Resealed the unit and ran the next season with the same result. <br />There isn't any visible cracks in the case. The driveshaft does have some left to right movement (not sure if this is normal). <br />Thought there might be a problem with bearing housing causing water to leak in but the rollers look fine as well. <br />Propshaft is smooth and snug.<br /><br />I've had the unit sitting assembled full of kerosene and not a drip.<br /><br />Any help would be greatly appreciated.<br /><br />Vic.
