Milky oil leak
huntingdeer
I have a 1970 johnson 25 hp.i just got the boat and I ran the motor in a drum for about a hour.when I pulled it out I seen a milky oil leaking out of the weep hole near the fill plug.so I drained the foot oil and it was a orangeish color.it looked good to me.no water in the lower unit.should I be worried? I know the gas is mixed a little rich but no worry’s will fix that later.
Oil that is mixed with the gasoline has to go somewhere.------Some of it actually goes right through the motor.---It is 100% wasted out the exhaust ports.----You see that as sludge in your tank and leaking out the weep hole.----Check the thermostat as they are often stuck open or missing.----Install a new water pump impeller if you do not know how old yours is !!
Crosbyman
and clean out that weep hole to keep it weeping properly otherwise crud piles up use a pipe cleaner or wire or with the lu is out clean the drain hole
Did you replace the shift rod o-ring ?----Did you pressure test the lower unit?
