further
- Jun 18, 2009
- 1,034
Started the winterization process today and figured I'd change out the gear oil first. Well it's as milky as milky oil gets....
A little background, purchased this boat last fall and had the prop shaft seal replaced by the dealer because I noticed it was leaking during the inspection. When I took delivery of the boat, before putting in my slip for the season, I decided it was best for me to do a full service on the outdrive because I didn't trust the dealer and wanted to install fresh bellows. So I pulled the outdrive and there was gear oil in the old bellows.... Opened the outdrive vent and gear oil came out, opened the drain and gear oil came out.... dealer overfilled the outdrive so I figured, the oil in the bellows was due to the pressure from the outdrive being overfilled. So drained, cleaned everything up and pressure tested. Held pressure and vacuum per spec. Installed new bellows, refilled outdrive and all new o rings.. All good.
So now since the bellows is new, prop shaft seals are new and outdrive held pressure and vacuum in the beginning of the season what could've caused the water infiltration?
I have to winterize the motor and need to run it to change the oil and fog. So the plan is to refill the outdrive w/ new oil and get my winterziation done. Should I flush the outdrive (fill with oil and drain again or can I just fill it and run the motor for winterization - maybe like 30 mins of run time total).
Once I'm done with winterization I will remove the outdrive, check the bellows (hopefully no water or gear oil there) and pressure/vacuum test and see whats going on...
