I have a 1977 Evinrude 15hp engine model # 15704M
Just recently i started to get a milky belch when I start the engine and on further examination of the prop, the inside exhuast port on the prop has a milky coating. I drained the lower unit and no water or mily residue in the LU. The oil level was slightly low, but no sign of water leakage. At the same time I noticed that I only have a dribble of water exiting from the water pump indicator. I removed the LU, inspected the water pump and it looks like new since it was just replaced about a year ago. While the LU was off I noticed that the exhaust port through the engine was also coated with a layer of this milky paste like film. I cleaned all of this out and it then re-appeared about a week later. I'm thinking I have a seal going bad in the LU, but how would this relate to the lack of water from the water pump indicator
. is it possible the milky paste has plugged somthing up?
Any adivice would be greatly appreciated
