Re: Min Kotta
If the 46# TM has a 3" motor housing, a Motor Guide 3 blade prop will fit it with a bit of modification. Modifications; take a little bit (1/8" or so) off the prop hub where it contacts the motor housing, then add a couple of washers under the prop nut if needed. To shave the prop hub I chocked it up in my drill press and hit it with a file. I've done this to a 70# and 50# MinnKota TM's and it worked fine.
