Sea Rider
- Sep 20, 2008
- 12,345
Nonsense Issue: What would be the minimum gasoline to have inside tank whille on choopy seas and start to experiment engine fuel starvation while cruising at 3/4 wot speed ? Choopy seas rocks gasoline inside tank and at some point pick up hose will suck air and motor misfire. If so, do you need to prime bulb again while on plane ? Assume the instant solution will be to reduce throttle, re arange tank horizontal level and go to port...
Happy Boating
Happy Boating
