minkota riptide part missing help
wilson750
I purchased a used minkota riptide.it appears there should be a gasket or part where the shaft is held? I attached some pictures.if anyone knows the part missing and where I can purchase.
Wee Hooker
You can call Minn Kota or go to any online /brick and mortar Minn Kota authorized service center. A quick google search will give you contacts for all.
wilson750
Anyone have this type of Minkota riptide with door and latch? There has to be some sort of flnage I am missing. I called minkota and they need a ser #. Well the sticker that has the ser # is gone. So hopefully somone on here has the same one!!
wilson750
Does anyone have this same Minkota RipTide trolling motor?
I purchased this 55lb thurst motor and It appears to be missing a flang to keep the shaft tight in the latch and door.If anyone has the same unit and could tell me what is missing it would be a great help!! I called Minkota but the ser # sticker is missing off mine so they can not help me out.
Attached is a pixs !!
GA_Boater
Next time just start one thread instead of the extras in different forums. Makes it hard for us to help you.
wilson750
Thanks GA Boater!! I found the part i needed now!! Sorry for 2 posts. I was not getting any help in the trolling motor forum. Thought i would get more help here!!Thanks a million!!
wilson750
sorry about the 2 posts. I was not getting any help in the trolling motor forum.Thanks again for your help!!
