So, I have a question. I understand that the Minn Kota Endura Max is more energy efficient than the Endura C2 line of trolling motors. But, what I am unsure of is how much exactly. From what I understand, the C2 basically uses the same amount of power regardless of what speed it is running at. So, it uses the same amount of juice if it is in F1 as it does in F5. The change in actual speed is simply done by means of resistors which change the speed of the motor, but doesn't cut back on the power being used. As apposed to the Endura Max which has digital technology and uses only the power necessary to run the motor at the speed selected. So, with the C2 if I had to make a long trip, it would be best to run the whole time in F5 to maximize distance traveled before the battery died. Is that assumption correct? Am I correct in my initial understanding that the C2 motor uses the same amount of power regardless of the speed it is being run in?
