Re: Minn Kota Engine Mount good, bad, or ?
Anyway, he had one of those trolling motors on his 20' Ranger.
A 20' Ranger with an outboard is a lot less to push than a 22' cuddy with an I/O, a lot less battery capacity required. I have a 70# transom mount TM (not and engine mount) on my 18'er and can only get 5-6 hours out of 2- group 29 batteries. If conditions are good or if I'm going with the wind it works OK. If going into the wind or if there are crosswinds it works terrible. (my 18'er is a lot less than a 20' cuddy too...)
I will need to use the 160# thrust motor.......it is a 24 volt system.
anyone know if these batteries could be connected to the alternator, so they could charge while running the on-board engine?
For the capacity you'll need, I think you'll need to go with 2- 4-D batteries. OR, 4- 6V golf cart in a parallel/series configuration.
The 24V bank can be charged off an I/O's alternator, but it needs to be wired correctly and it's dependent on the alternators output. I do this all the time and it takes 3 hours or so, with a 105 amp alternator putting out 60 amps at idle speed. The stock 60 amp alternator doesn't put out much at idle speed (20-30amps?) so it would take for ever to charge, unless running at high RPM for hours, which is unrealistic. You can't run the high output alternator at high RPM to throw 100 amps at the batteries, too much current, to quick of a charge, the batteries will cook. (30 amps/battery like I'm doing is pushing it...)
I have one of the troller batteries on an AB battery switch as backup for the main engine, then both trolling batteries connected to a Marinco 12/24 receptacle. Plug in the jumpered 12V plug to series connect the batteries,,, then throw the AB switch to charge. Flipping switches and plugging in is cumbersome though. There are automatic/electronic chargers, but nothing I've seen will carry the current needed. An ACR could be used in place of the AB switch to make things easier.
Then you have the I/O's power steering issue. And, an EM troller will have slow steering response just by design or using the steering wheel. I run a Troll-a-Matic trolling plate that calms my I/O to trolling speed, though it doesn't some without drawbacks, diminished steering, blocks prop in reverse.
Bond-O's suggestion of a couple buckets or trolling bags deployed mid-ship would get you the results you are looking for, cheap.
Actually, a bow mount trolling motor would work better at controlling a 22' boat, than a transom mount. You would be in the 36V range and charging off the main wouldn't be an option anymore (unless you did some really creative wiring).
