gcornelisse
- Jun 11, 2008
- 14
I recently ran my 4 year old Minn Kota Maxxum trolling motor for about 5 minutes or less at just about 100% power. When I let off the button on the foot pedal, lowered the power down to about 30% to fish and then touched the button again, the motor was dead. Of course this happened on a gas restricted lake. Go figure! Huge thanks to the guys who helped tow us back.
I got it back home and we opened the lower unit to find both brushes were stuck in their channels. Using a small flat-head screwdriver they only needed a little nudge to be freed. I slid the brushes out to clean them up and get the channels clean of any dust and grit, leaving them connected by their leads. I reinstalled the brushes, and they seem to slide relatively clean and free of any hangups. I didn't see anything in the lower unit that looked damaged or burned.
There was no evidence of water leakage, but I reassembled the lower unit with all new Minn Kota o-rings and seals using a little light grease to keep the seals from pinching or rolling when putting everything back together. I was careful to realign the motor housing using marks I had made before taking it all apart.
I also inspected all the wiring from the 3-prong plug, through the pedal and down to the brushes. I found a little resistance in the wiring from corrosion inside the plugin. I cut back the wire insulation to get clean copper and replaced the plug with a brand new one, exactly the same. A final resistance test indicated a lot of improvement.
Since having the boat out again, there seems to be about 20-30% less power/thrust, maybe more. The the prop spins smooth and free by hand. Having fished with this trolling motor for more than 4 years, I've become very familiar with using it at different percentages based on the conditions... wind, current etc. Previously, running it at 100% was virtually uncontrollable from all the torque. Now 100% is super easy, even with the cable tension backed off. I used to troll the banks between 20-30% power and now I'm using it in the 35-50% range. I think the loss at the higher end is even greater. So, something is still not right.
Does anyone have an idea what I should be testing, looking for, or parts I should be replacing at this point?
Thanks in advance!
Thanks in advance!
