Troubleshooting a Minn Kota 24V Riptide trolling motor, any constructive advice is appreciated! Here is a link to my youtube channel showing (mainly audible) the issue.
https://youtu.be/2Q00bQoD8Rg
Here is what I know from troubleshooting so far:
-Intermittently will work fine
-Intermittently will make the clicking noise
-Intermittently will not work at all
-Receptacle has 25 volts steady on multi-meter
-Wiring on trolling motor side of plug has 24 volts steady on multi-meter
-Hot wires going into the circuit board have 24 volts on multi-meter
-When it was not working at all, the red wires coming out of circuit board showed 1-2 volts no matter the handle position.
-When it was not working at all, the hot wires coming from the trolling motor plug red 24 volts when the handle was in the off position and then would read 1-2 volts when the handle was moved to any power setting (this made me think it had a short somewhere).
I'm thinking its the circuit board but am open to suggestions?
