flamingmike
- May 10, 2016
- 1
Hi, I bought a Glastron GT205 2010 (with 4.3L, Alpha and wakeboard tower) and it came with a Mirage Plus 19P prop. I don't know much about propellers and I'd like to understand why this particuliar one was installed. From what I read, it is a very good prop and it's low pitch should make it good for hole shots but worse at top speed. It runs at about 46-47 MPH at WOT 4800 RPM.At this pitch, I read that my engine should overrev but it does not. Is it a side effect of the larger size at 15 1/4 inch or the total weight of boat and equipment? Should I keep it or change it? Although it has a wakeboard tower on it, it`s not my primary use. I rarely go top speed too but usually do 3000-4000 RPM cruising around with familly and friends.
