turbocorrado
- Aug 14, 2013
- 251
got an intermittent misfire issue, thats becoming more and more prevalent. no loose grounds, no wiring issues, only is happening when gassing it from forward idle, once it starts it misfires badly no matter whats going on and the boat is essentially imobile. turning the boat off and back on a few times has been clearing it up for now. new fuel pump, fuel filter, cap, rotor, wires, plugs
i already know the control module has issues as it is setting off the coolant temp alarm anytime the boat tries to get on plane (its disconnected and is fine disconnected. new sensor and wiring is fine) im tired of putting money into this boat, were getting a new one after next season, so i need a cheap fix to get me till then. all my boating buddies and myself included, think an hei distributor setup is the cheapest easiest fix for my scenario
boat info 97 wellcraft eclipse - PO sunk it twice
4.3 mercury v6 - early thunderbolt 5 setup - NO knock sensors
2bbl carb with electric choke
