sreskunked
- Oct 10, 2005
- 4
I have had a small misfire under acceleration although you could accelerate right through it. The other day I went out and could not get the boat on plane or the engine to rev above 3000 rpms. I took the boat back to the dock and got several bottles of injector cleaner. Poured it in and went back out. Was able to slowly accelerate and eventually get it to run clean. After fishing and driving around the rest of the day with no problem, I pulled all plugs and found #1 cylinder plug to blacker in color than all other. The porcelain on all plugs where brown although #1 had black soot on it. I also have changed the water separator and found no sign of water in the fuel. Took the boat out again and has a small misfire at idle in gear and misses a couple of times when dumping to full throttle from idle. Is it possible that I have a bad coil or what do you guys suspect. The motor is a 2002 with 140 hours.
