Misfire
oldman137
I have a 2007 5.7 Mercruiser At 3200 RPM it runs perfectly for 20 minutes then starts to misfire. It feels as if it is being fuel starved. I ran the engine and removed the air cleaner / flame arrester and looked down the chokes of the twin barrel. The port side choke looked normal but the starboard choke the fuel was not a steady stream it was spurting. During the problem I have removed the gas tank cap in order to prove it is not a plugged vent problem. The engine noise changes as this problem happens, it sounds almost like sticking lifters but I'm not sure.This can be reproduced as often as required and is always the same within a minute or so. The engine has about 90 hours on it and has just been fitted with a new carb (When I purchased the boat the engine rebuild had been completed with an automotive carb).
Re: Misfire
Ayuh,.... Sounds like the carb needs another rebuild to dig the Crap out of it...
How much Crud is in the fuel Filters,..??
oldman137
Re: Misfire
Fuel filter is new (less than ten hours) and clean. If it is crud in the carb why will it run for 20 minutes just fine and what would cause the noise like sticking lifters?
Drop the RPM down to 1000 and the misfire and the noise goes away
Re: Misfire
Ayuh,... My guess is your hearing Detonation, caused by a Lean condition...
Btw,... 10 hours can be like 10 Years if you picked up a dose of Water...
TiredoleBoy
Re: Misfire
This
I have seen rebuilds get dirt from the tank in an idle port and cause to occur.
