Miss on 1983 470
joner
I'm having a problem with losing power as the rpm are coming up as well as a steady miss in one cylinder. It's aggravated by using the trim but I can't find a short in that system. I thought the new coil and wires had solved this problem but its starting again. Also any suggestions for type of spark plugs for this engine would be appreciated. <br /><br />Thanks
festx
Re: Miss on 1983 470
Sometimes it's not an electrical problem. Try adjusting the fuel mixture on the carbs. It could be to lean.
JB
Moving to I/O
Bob_VT
Check your exhaust manifold... If it has a hairline crack (the older cast iron ones are popular for cracking) it will spread under the exhaust heat and kill the #4 cylinder. <br /><br />I just changed mine over to an aluminum manifold and no more problems.<br /><br />Also check your coil... when coils fail they tend to fail at higher rpm and when heated up.<br /><br />Bob
