Missfire at part throttle, dies at idle
Brent223
I got my boat, a 16' Bayliner with a 70hp Force outboat, this Spring. Due to weather and other stuff going on, I've only had the boat out three times. My first outing confirmed a water leak in the lower unit, and the second outing confirmed my repair (new impeller and seals) fixed the leak. I also replaced the fuel filter, a leaky fuel line, and the spark plugs.<br /><br />Since I got the boat, if it idles for more than a few minutes the motor will die. It starts right back up, however (lucky me).<br /><br />On today's outing, the motor seemed to run rougher than usual. I detected a missfire while accelerating, noticable at lower RPMs. The top end seemed normal. Hard to say if the missfire was gone at higher RPM, or just not as noticable.<br /><br />The spark plugs are gas/oil fouled, not too bad. I'm going to rebuild the carb and install new plug wires. Because the top end seems OK I think the fuel pump and primary ignition aren't the problem.<br /><br />Thoughts/ideas/experience?<br /><br />Thanks!
roscoe
Re: Missfire at part throttle, dies at idle
Make sure you use solid wire core plug wires. None of those high resistance auto wires or you will fry your ignition.<br /><br />Year of motor?
Brent223
I was going to use the OE wires - they're only $6 each.<br /><br />This is a 1994 motor.
