Missing Anode/Fin
Bayliner175xt
How'd just wondering our alpha 1 drive is missing this anode/fin. (See Picture)
will adding this make my steering any easier.
Bayliner 175 with a 3.0 alpha 1 drive, no power steering.
everything works fine but once under way it's a little harder to steer.
It also tends to turn slight to one direction.
thanks
dubs283
Re: Missing Anode/Fin
it won't make the steering "easier" like power assisted steering would
but, it WILL counteract the torque of the prop against the drive - so if the wheel pulls hard one way, this will help counteract that, just make sure you turn it the right way - may take a few tries to get it set right
the one you have pictured there is okay for an aluminum prop, if you have stainless you need the high performance tab
