model name
rickwan
I have a Mercury 200 HP/ V-6/Carb Serial No: A 148279,How do I know the engine model name and year of manufacture. :confused:Can I interchange the lower unit with a Mercury 150hp Black Max Series?
Backlash
Re: model name
You've got a 1985. Don't think the lower unit will interchange with a 150 Black Max.....but I'm only guessing on that. Maybe someone a little more Merc savvy can help.<br />Backlash
rickwan
Re: model name
Thanks BACKLASH,what's the model's name.Is it a black max too?This engine will start on idle but quits as gear is engage.Any idea or help.Thanks to all you guys out there. Happy boating,till I get mine running. :confused:
Spidybot
Re: model name
Rickwan,<br /><br />If you look in Merc Parts Express here you'll se parts for your motor.<br /><br />Gear housings change on those motors - high performance series uses the slimmer design units. Any dealer would know.<br /><br />Hint: Post a new topic, under a descriptive subject, for each problem you have. Makes it a lot easier to answer and follow a thread (one concerning your running problem and another concerning the lower unit). Remember also, that a search on these forums returns a lot of hits, often answering your questions even before you post them). :)
