Took the boat out again yesturday and no problems. Boated for about 45 minutes and then stopped and anchored for about 3 hours in shallow water. ON the way back we threw out the tube and pulled it at idle. After about 2 minutes, the engine loses power and stalls. I got it going again however it wouldnt idle and needed to stay at or greater then 1800-2000rpm. Got it home and started playing with it. IT will idle now(after multiple failed starting attempts), however if it is around 2000rpm or greater and is rapidly/moderately brought back to neutral it will stall. IT will try and get going but doesnt have it in it. I cleaned the carb a little bit and it ran better. However I dont know what my next step should be. IT will run in neutral after warming up but it isnt smooth like before. PLugs are good, gas is good.
1985 Sea Ray
Mercruiser I/O
4 CYL GM 170 HP MCM 170MR
1985 Sea Ray
Mercruiser I/O
