Monday Morning Nerd
NYMINUTE
Dear Tech Support: <br /> <br />Last year I upgraded from Girlfriend 7.0 to Wife 1.0. <br /> <br />I soon noticed that the new program began unexpected child processing that <br />took up a lot of space and valuable resources.<br /><br /><br />In addition, Wife 1.0 installed itself into all other programs and now <br />monitors all other system activity. <br /> <br />Applications such as Poker Night 10.3, Football 5.0, Golf 7.5, and Racing <br />3.6. <br /> <br />I can't seem to keep Wife 1.0 in the background while attempting to run my <br />favorite applications. <br /> <br />I'm thinking about going back to Girlfriend 7.0, but the uninstall doesn't <br />work on Wife 1.0. <br /> <br />Please help! <br /> <br />Thanks, <br /> <br />A Troubled User <br /> <br />______________________________________ <br /> <br /> <br />KEEP READING <br /> <br />______________________________________ <br /> <br /> <br />REPLY: <br /> <br />Dear Troubled User: <br /> <br />This is a very common problem that men complain about. <br /> <br />Many people upgrade from Girlfriend 7.0 to Wife 1.0, thinking that it is <br />just a Utilities and Entertainment program. <br /> <br />Wife 1.0 is an OPERATING SYSTEM and is designed by its Creator to run <br />EVERYTHING!!! <br /> <br />It is also impossible to delete Wife 1.0 and to return to Girlfriend 7.0. <br /> <br />It is impossible to uninstall, or purge the program files from the system once installed. <br /> <br />You cannot go back to Girlfriend 7.0 because Wife 1.0 is designed to not <br />allow this. <br /> <br />Look in your Wife 1.0 Manual under Warnings-Alimony-Child Support. <br /> <br />I recommend that you keep Wife 1.0 and work on improving the situation. <br /> <br />I suggest installing the background application Yes Dear to alleviate <br />software augmentation. <br /> <br />The best course of action is to enter the command C:\APOLOGIZE because <br />ultimately you will have to give the APOLOGIZE command before the system <br />will return to normal anyway.<br /><br /><br />Wife 1.0 is a great program, but it tends to be very high maintenance. <br /> <br /> <br />Wife 1.0 comes with several support programs, such as Clean and Sweep 3.0, <br />Cook It 1.5 and Do Bills 4.2. <br /><br />However, be very careful how you use these programs. <br /> <br />Improper use will cause the system to launch the program Nag Nag 9.5. <br /> <br />Once this happens, the only way to improve the performance of Wife 1.0 is <br />to purchase additional software. <br /> <br />I recommend Flowers 2.1 and Diamonds 5.0 ! <br /> <br />WARNING!!! DO NOT, under any circumstances, install Secretary With Short <br />Skirt 3.3. <br /> <br />This application is not supported by Wife 1.0 and will cause irreversible <br />damage to the operating system. <br /> <br />Best of luck, <br /> <br />Tech Support
dolluper
Re: Monday Morning Nerd
FUNNY !!!! my tech support couldn't answer that one
spratt
There is one other important background application that needs to run as a Terminat and Stay Resident (TSR)...the name of it is PRETEND TO HEAR 4.1, and it helps to have the similar app called IGNORE 2.2 running also.
NYMINUTE
Originally posted by FlatBottoms:<br /> There is one other important background application that needs to run as a Terminat and Stay Resident (TSR)...the name of it is PRETEND TO HEAR 4.1, and it helps to have the similar app called IGNORE 2.2 running also.
These should not be confused with Litigation 5.0, and Better Box Living 1.0 :D
jtexas
I've heard that you can get "cheat codes" from the internet that will let you run older versions of GIRLFRIEND concurrently with WIFE 1.0 ;)
ebbtide176
Better Box Living - LOL :D <br /><br />upgrade to Doghouse Addons by the DIY'r
silenscurator
I've heard that there are a few gliches with the older versions of Girlfriend, and that Wife 1.0 always cracks the cheat. Also, do not attempt to run New Girlfriend applications as this will lead to a complete crash of all operating systems. :D
OLDSPUD
so thats what wrong, say a couple words then goes to autoload.<br /><br />Didn't think I had enough memory to run that program.
jtexas
Originally posted by spudbartlett:<br /> so thats what wrong, say a couple words then goes to autoload.<br /><br />Didn't think I had enough memory to run that program.
Problem with WIFE 1.0 is that it takes a big hard drive to get it installed; afterwards, hard drive usage drastically declines but you'll need all the memory you can get. ;)
