Mooring anchor, end of season.
olddawgsrule
I've always been a trailer guy and this is my second season having a boat moored in a Mooring Field.
Today, when pulling her out, I came across to others in the same field pulling their mooring anchors.
I just had to ask.. Why?
Both said they have had their chains break. One after 2 years, the other after 3 years.
I'm about to go back out next weekend and pull mine after hearing this.
Is this what you guys do?
alldodge
Only way I see a chain breaking after 2 years is it was not galvanized and it was probably smaller then 3/8 inch. A 1/4 inch high test chain will take quite a while to wear down, but cheap steel chain can take less. most use cheap chain at the hardware store. Use 1/2 chain and it will last a long time.
What are you using?
Edit: wonder if someone is steeling the morning and cutting the chain to make it look like it's breaking
Ayuh,..... My 2 moorin's are 8 or 9 years old, 1/2" chains right to the lines,....
Next week-end, I'll be tyin' the steel dock cables to the chain's ends, back to shore,.....
Puttin' the houseboat back on her wagon Saturday mornin',....
Hopefully get the tinbarge on it's wagon some night this week,...
