- Jul 18, 2011
- 18,285
70 lbs is not much for a mooring anchor and a danforth is not designed to serve as such either. Regular boat anchors require a fair amount of scope (5:1 or more) and a mooring anchor uses little scope (2:1) .
A mooring anchor for a 36' boat would be approximately 500 lbs
You should perhaps consult with some of the mooring service companies in your area. Additionally many areas regulate the mooring spaces, so you should see if any 'rules' apply.
I have a 500 lb diamond (dor-mor) anchor mooring my 33 formula. Alternatively, I could have used a 500 lb mushroom anchor, but the diamond anchor is better for the shallow water where I moor.
