1984 Johnson GT 150. Checked gas, no prob. Cleaned Carbs, new plugs, flywheel key is OK, compression 84 lbs all 6 cyls. Still won't start. Backfires. This engine is a cross between an 83 and 84. Should run on leaded gas, we are running 89 octane unleaded. Is there anyway to check timing? Acts like it jumped time. Could it be the control box? There is a prob. there, oil buzzer goes off, that sensor is not hooked up to anything.The thingy attached to the ignition switch came off, engine died, put it back on and it ran fine. At wits end. Any ideas, will try anything.
