I'm haveing basically the same problems with my 1974 65hp Johnson. Starts fine, idles fine, but when you acclerate it dies. After repeated choking (while idling) it'll finally take off & run fine until shut off, then back to the choking process. Have changed gas hose & primer bulb, plugs, and ran fuel additive & carb cleaner. Is it time for a real mechanic to work on it?
