Re: More newbie questions.......shift lever?
Hi, it's me, the newly acquired Johnson 1963 10hp QD-24. My new owner doesn't know what the lever on my STBD side is for. I'm pretty sure he knows that the center position is Neutral and for starting but he is confused about the forward position and all the way back. He is unclear about these positions and how they relate to throttle positions. Can you guys help this poor sole before he blows me up. Thanks........Johnson 10 hp signing off.
Um, you wouldn't be the owner would you? Just kidding.
You definately should invest in a owner's manual.
www.outboardbooks.com They have copies of the book that came with the motor when it was new.
It is the gearshift. Center is neutral. Forward is forward gear. Back is reverse gear. Put the throttle (twist grip) all the way toward "slow/stop" and then put the shift in neutral. Then turn the twist grip toward "fast" as far as it will go (in neutral). That is the starting position. Ignore what the wording on the twist grip may be, they are usually way of.
Once it starts, slow it down to slow idle and "snap" the shift lever into gear. Go as fast as you want with the twist grip. Be sure to slow back down to slow idle before shifting to neutral or reverse. Always "snap" it into gear with a quick decisive movement. NEVER "ease" it into gear---that causes severe and expensive wear.
Fuel mix is 24:1, one pint of TCW-3 outboard oil to 3 gallons of gas. Make sure the water pump works, don't burn that nice motor up.
