More noob questions
ba1335
Hi again. There should be a specific forum for noob questions and simple "how to's," (other than the safety forum-which all us noobs should read). However, since there is not a noob channel I must ask these beginner questions here.
I bought a boat, and got a good deal......now what?
I signed up for the safe boating class and got it insured before I drove it home, but know I'm perplexed. The seats need some additional cleaning, what kind of cleaner do you use on the vinyl seats? More importantly how do I 'de-winterize' the engine? There's not really a list of steps to take to properly turn the thing on. What kinds of things should I check for before I fire it up? I know I need to run the blower for a bit before I turn it over but what else do i need to do?
JASinIL2006
Re: More noob questions
If you search this forum, you'll find all sorts of relevant information addressing just those sorts of questions. I'm in the same boat (pun intended) as a new boat owner, and I've learned tons here already. I also took an online boating course and it really taught me a lot of useful information.
There are also some pretty good books available for first time owners, but the reality is that, between this forum and the online course, most of the books have just repeated stuff I'd already read.
One great piece of advice I see a lot is to take an experienced boater with you on your first outings to help you learn and avoid mistakes.
I'm sure more experienced voices will chime in, but I really think this board is a great source of information and help.
Have fun!
Utahboatnut
First thing is we need alot more information on what you have before advise can be given out. Is it an I/O, outboard, merc, Volvo, fiberglass, aluminum, etc. Give a full description of what you have for better responses, if you arent sure take a bunch of pictures and post them here and we can get you started. Otherwise to "turn the thing on" could mean anything. That said no matter what it will need an attachment for your garden hose to supply water to it for cooling, but we dont know even which attachment to reccomend.
JimS123
I use the same cleaners and waxes that I use on my cars. You need to have a manual for your motor - that will tell you startup procedures, etc. The Course will tell you the rest.
tpenfield
Your local marine store should have some vinyl cleaner, or you can order some online. It will have a mild abrasive plus a conditioner that the vinyl will appreciate. Rumor has it that you should not use Armorall on the vinyl . . . I think it makes them get dirty quickly or something like that. I remember I tried it once just to see what would happen.
De-winterizing the engine . . . start it up, and presto - it is de-winterized.
Of course there might be some pre-season prep that has to be done in conjunction with 'starting it up'. It all depends on how much you do during the post-season prep. Since I'm lazy, I usually end up changing the oil and stuff in the Spring. Usually I keep a list of stuff that needs to be done to the boat and update it throughout the season. Then I decide on what I will do in the Spring versus what I will do in the Fall.
Before I start the engine (oopps, I mean de-winterize the engine), I usually charge up the batteries, take out the spark plugs . . . then I spin the engine with the starter until I see some oil pressure come up. This is so the oil system will be primed 'cuz much of the oil drained down during the winter. It also primes the gasoline line. Having the blower on when you do this sort of stuff is a great thing, as you will get some amount of fumes when spinning the engine.
Under normal starting, etc you are supposed to run the blower for 4 minutes. I only run it for about 3 minutes, but don't tell anybody. As an added measure, I check the blower exhaust vent to see if I can smell fumes. ( I learned that in boater safety class). Keep in mind that you will always smell some level of oil fumes. It is the gasoline fumes that are troublesome.
Once I get the spark plugs back in and reconnect the wires, etc. I'll run the engine on the muffs for a while. I check to see if the temperature comes up like it should, the oil pressure, the voltage all that good stuff.
If I do my Spring prep drill a while before I plan to launch the boat , then I'll usually start it up the day before I go to the launch ramp so that I do not end up being YouTube fodder at the boat ramp.
Anyway, that's enough rambling from me for now.. . . It's lunch time and I'm gonna take a walk outside.
Enjoy.
Sunsetrider
For cleaning vinyl seats I have had great success with Marine Spray 9, followed by a vinyl protectant. That stuff is actually quite amazing. And available everywhere.
ba1335
Thanks for the help guys. The boat I have is a '96 Sylvan 17ft, with a 4 cylinder 3.0l, Alpha, Gen.II (I believe. Bond-o told me that when he looked at the ad, and I lied before, I actually haven't driven it home, so I can't check it yet). I have a buddy with the muffs so we can use those to check the engine before I actually take it out.
tomdinwv
Scroll down to the Mercruiser section on the main page and check it out. All the info you need is listed in the stickies in that section. Tells you everything you should check to "de-winterize" your boat. Good luck and happy boating!
