Okay...I have read lots on the overheating problem that these motors seem to have...now I am getting a little mad, even, because this is a motor, and it should be capable of running for an afternoon without trouble.<br />As near as I can figure, mine cooks when run at over 3,500 rpm? Is that the rev limit, or do they run faster when correct?<br />I believe that I have done the usual that are outlined here...last season a boatyard replaced the exhaust elbow. I have replaced the outdrive impeller this year, and know that it pumps with authority. I have also replaced the 3 inch heat exchanger with a new 4 inch unit. The internal water pump works...pumps a lot.... The condition exists when the 160 degree thermostat is in place or not. Timing is correct. <br />Is there a schematic anywhere that has details of the cooling routing....???? I have the Clymers manual....<br />Thanks a bunch.<br />Peabody
