turtle1173
- Nov 29, 2001
- 437
While I was doing a compression check this morning I noticed a problem. I warmed the engine up using the proper hose attachment. I noticed water spewing out of the back starboard screw that holds the lower unit off. I turned off the engine and then the hose. Water continued to stream out of the screw or around it for a minute or two.<br /><br /> Break it to me gently. What problem do I need to deal with? I changed the lower unit oil a month ago. No particles & no water then. Also understand that this motor sat for several years before I've been using it the past 4 months. Could it be that the lower unit gasket has developed a leak? Or could it be a problem with the water pump? It has not been replaced, as the mechanic that cleaned the carbs and got her running said she was working fine. Please let me know.<br /><br />Shane
