Most likely situations for skeg to hit pavement
colbyt
Master Chief Petty Officer
I have a lightweight stick clamped to my transom and plan to go out and drive around a bit to see if it bottoms. As I have very limited experience towing with an OB mounted, my question is where or what situations are the most likely places to have problems? Speed bumps and aprons I can visualize.
Re: Most likely situations for skeg to hit pavement
Ayuh,... Any Radical change in grades is suspect,... Curbs are probably the most common,...
lrak
x2 on the curbs. If you can back into a parking space and the skeg clears a tall curb at the back end of the space, that would take care of all of the common worst cases.
Mi duckdown
Pics of your motor/ trailer setup would help. one pic is worth a thousand words.
