dafirstboat
- Mar 3, 2005
- 1
Hello All,<br /><br />I'm a complete first timer to the forum as well as the boating world, just so every one knows in case I say something stupid. Anyway, on to my problem with the boat.<br /><br />Last summer I bought a 1981 Thompson with a Mercruiser 120 and alhpa1 out drive. The guy had an issue with the distributor, (the stator screw came lose and pretty much tore the thing off) anyway he replaced the parts and couldn't get it running so there it sat for a couple years. I bought it pretty cheap thinking I might be able to get it running, I was able to by cap and plugs and set the timing and BAM the thing fired. So to the lake I went. I took it slow for a while but then started to speed up the thing seemed to get pretty hot and smoke but with 2 years of storage I kind of figured it was that, then it started to squeal and higher RPM's but would stop when I backed it down. So back to the trailer and into the garage for some more tinkering. I thought maybe it might have just been the alternator belt since it was stretched pretty good and a little loose. I replaced it, changed the oil and filter (which was very thin, I think with gas) and back to the lake. This time I stayed at the dock for quite some time until it was good and warm and once it warmed up the squeal came back only now it was also doing it at idle. Since I was at the dock with a buddy I was able to get back to the engine and try to see where the sound was coming from, it sounded to be coming from the very back of the motor but was not able to figure out exactly where it was. I'm afraid this is a main bearing or something and the engine will need to be rebuilt, something I'm willing to do if thats the problem. Also I don't know if this is matters or not but when I changed the plugs the outside of the front plug was pretty rusted around the base, the threads and what not seemed fine but there was rust on the plug, not sure if this is a normal thing or not or even if it has anything to do with the squeal just trying to give as much info as possible.<br /><br />But thats about the story, any suggestion would be greatly appreciated. Even if it is just a suggestion on how I can check it out to know its the bearing or something else for sure before tearing it all down.<br /><br />Again hope this isnt to long or winded just trying to get as much info in the first post as possible.
