Motor bogs down in water when accelerating
Bke12345
Hey all. So I got my boat in the water, finally!! After a lot of time and money. I got a 1979 Mercury 150 outboard in-line 6 with 3 carbs. Have an issue because I’m trying to figure out why the motor bogs down when I try to accelerate in the water and it stops every time. I can accelerate all day long on water muffs out of water but when I put in the water and try to accelerate it bogs down and dies every time. Does anyone know what would cause this and is there a way to just I guess the carbs?
Just try and open the 3 low speed mixture screws 1/8th turn and test run.----Repeat as needed.
Bke12345
Is that the little brass screws that’s close to the top of the carbs?
Bke12345
Where the little hoses go from one side of the carb to the other side of the float bowl?
You should be able to find a screw ( spring on it ) at the upper right side on front of the carburetors.----Not brass either.
Bke12345
Bke12345
Oh ok. Well what would be the brass screw for on it. It has a hole in the middle of it. Would that be your oil fuel mixture?
Stop looking at the little hose and brass screw with the hole !------That is something to do with a " back drag " feature.----It leans the motor out at full throttle.----And nothing to do with oil mixture either.-----Look for a screw with a spring !-----I don't mind trying to help but perhaps a factory manual should be on your wish list !
Chris1956
Mercury did not make a 150HP inline six motor in 1979. The last one was in 1977.
However, they made a 140HP inline 6 in 1979. If you want to get the right parts or a manual, you should search motor year by serial number.
BTW - Racer is dead on. If the motor idle well, the carbs are likely too lean for acceleration.
Serial # should be posted.----Should almost be a requirement to allow posting on various sites !
eddiesweber
I had the same problem with a 1968 Merc 1000. I thought I was adjusting the carbs wrong, but it turned out to be a compression problem. Here is the procedure I used to find the problem. First, I spent days trying to adjust the carbs. The engine would run great until I put it in the water and I would have the same problem. I eventually noticed that if I adjusted the bottom carb (of 3), nothing would happen? If I adjusted either of the top 2, I could make the engine die or start running rough. So I spent a bunch of time trying to adjust the bottom carb, but it would just do nothing. I decided to tear the engine apart and while I was cleaning it, I noticed a hole on the side of the block!! It looked like a bullet hole? Once I noticed that, I went down to O'Reily's and borrowed a compression tester. Sure enough, there was almost no compression in the bottom 2 cylinders. Ouch. I think he top 4 cylinders would keep the engine running when it was out of the water, but as soon as I put a load on the engine it would bog down and die. Go borrow a compression tester from your local O'Reilys and make sure you have compression on all 6 cylinders before you keep trying to adjust the carbs.
Bke12345
I have an update on the bogging down on load problem. When on the water Sunday I tried to adjust the carbs in forward gear as I read on to do. It seemed to work alittle And I accelerated and it seem to work. But not fully. I got it home and parked the boat for the day. The next day I put a barrel under it and tried the process again with a load. Now this time I can’t seem to get the engine to even start up. It’s like I did something to the adjustment on the carbs to which now I can’t seem to figure how to link and sync them to get the engine to start back up. Any thought on how I could go about this to get the engine to start back up to proceed the process on the load?
Chris1956
Set carbs 1-1/2 turns open from light seating. That will allow it to start, and idle.
I am not sure how you intend to set carbs in a barrel. If you had a test tank (large, covered tank), plus a test wheel, it could be done on land. Barring that, the water is the way to go.
You did set the throttle primary pickup timing and max timing, right?
